Tech: Drivetrain - Trucks 4x4 @ Off-Road.com
A system error has occured: java.lang.StackOverflowError
Tech: Drivetrain
  • Project K1500: Posi-Lok or Bust
    4x4 Posi-Lok makes an alternative front axle engagement system. This setup, referred to as the Posi-Lok, is 100% mechanical.
    Project '93 K1500: Tom Wood's Custom Drive Shaft Install
    Off-Road.com shows you how to install a Tom Wood's Custom Drive Shaft on your 4x4.
    Project K1500: Richmond Gear and Powertrax Extreme Traction System
    After upgrading to the 35-inch Pitbull Rockers the truck has been crying for a gear change.
    Transmission Overhaul Part III - Home Sweet Home
    Our Chevy truck gets a new torque converter, deeper transmission fluid pan, and final assembly by AAMCO.
    Nissan Xterra Aluminum Differential Cover Review
    Is an aluminum differential cover really better than the OE steel stamped? Off-Road.com takes a closer look.
    Project K1500: Transmission Overhaul Part II Dissasembly
    Once I got project '93 k1500's transmission apart I decided it might be best that I left it to professionals at my local AAMCO to reassemble.
    Project K1500: Transmission Overhaul Part I Overview and Detachment
    About 210,000 miles later I have finally decided to direct my attention to the transmission. It is the original, stock tranny that came with the truck all of about 14 years ago and has not had any complications.
    BULLY DOG PMT Review
    There comes a time in every young diesel truck owner's life where two little words hit and begin to nag at them. More Power!
    For our 6 speed manual 2006 Dodge Meg a Cab 2500 it was shortly after we had cracked 20,000 miles.
    Product Spotlight: Dynatrac Free-Spin Hub Conversion Kit
    Dynatrac Products is well known and highly regarded for making high-end, custom and extremely strong complete Dana axle assemblies for everything from competition rock crawlers to heavy-duty mining equipment.
Click here
